Goldie
2011 ZX6R part out. See Photobucket link for pictures>>>>
http://s1358.photobucket.com/user/Goldie757/library/2011 ZX6R
Parts are from a 2011 ZX6R. There may be cosmetic blemishes on certain parts and some may need cleaning so see picture link for details or ask me for additional photos. Parts are listed “without” shipping cost. I take cash on local pickup or PayPal (Add 3% if using PayPal). It is “BEST” to TEXT, PM or CALL me if interested at 757-572-4410. I tried to price every part reasonable as possible. Parts are located in Chesapeake, VA for local pickup. I can also deliver during many track days and CCS events. I ship within 2 days of “CLEARED” payment. Cheers my friends!!!
600 - LeoVince SBK Factory EVO II Full Exhaust System
850 - Traxxion Axxion cartridge AK-20 front forks - (Rash on bottom right fork) (Set up for 185 pounds)
650 - Penske 8983 "piggyback style reservoir" Racing Shock - (Set up for 185 pounds)
150 - Annitori RL by HM Quickshifter - (Includes shift rod)
200 - Woodcraft rearsets "with" Brake Pedal - (No brake side boot guard, use your stocker)
100 - Vortex clipons (51mm) - "Includes" both bars
140 - Motoholders Fairing stay with Ram Air duct
50 - Goodridge Steel braided brake lines
75 - MWR HE Air Filter
180 PC5
80 - OEM Ohlins Steering Damper - (Revalved by Ohlins USA for RACE) (Incudes Mounting Bracket)
100 - GBR Racing covers (Some rash on all pieces. See pictures)
80 - Motion Pro Quick turn throttle with three extra cams. (Rash on the top housing)
25 - Servo Buddy
70 - WPS Featherweight Lithium Battery
80 - CRG Roll-a-Click "Standard Length" Levers (Rash on the brake lever)
60 - EBC GPFAX front brake pads - 2 sets (Used) - Approx. 80% left
1100 - Frame (Clean Title but not in my name. I have the title and all paperwork to get a title in my
name if I wanted to.) Frame has some cosmetics scratches on the right side and a very small dent from a rock. Frame is straight and have no issues.
950 - Engine (Comes with Throttle bodies, Plugs, Coils, smog block off plates and front sprocket cover.
50 - Drive Systems 520 chain and sprocket kit. 15T Front & 43T rear sprocket plus 520 chain. Will need a
master link.
180 - Subframe & battery tray (Straight)
60 - Airbox with upper injectors (No air filter)
140 - ECU
75 - Wire Harness (Keyless ignition done, so its going to need a toggle or on/off switch)
20 - Clutch Perch & cable (no lever)
130 - Speedometer (Cluster) - (Mileage 2,764)
120 - Triple trees (Complete - Upper and Lower) - Key ignition circle rounded on the top tree. My bike was
keyless. The holes are still underneath the top triple to mount an ignition if needed.
185 - Front Nisin Brake Calipers ( No pads)
75 - Front Master Cylinder and Reservoir (No brake lines or lever)
75 - Rear Brake Caliper (Complete with line, MC, and Reservoir delete tygon tubing). OEM brake pads
included.
250 - Black Gas tank (Includes side panels and fuel pump. "No Gas cap included") . Pics forthcoming. Still
need to drain it.
25 - Control switch "Right" (Killswitch, start) (Some light scratches on the housing)
15 - Coolant bottle
15 - Front axle and nut
15 - Right Passenger peg "hanger only". What the exhaust muffler mounted to. No foot peg included. It's just
the hanger. See pictures
100 - Radiator (No Fan)
15 - Rear axle and nut
25 - Rear Tire hugger
40 - Rectifier
50 - Seat (Driver)
40 - Swingarm (slight dent on the right side, but still straight and fully functional)
20 - Rear shock linkage with dog bones
180 PC5
25 - Servo Buddy
master link.
140 - ECU
included.
need to drain it.
15 - Coolant bottle
40 - Rectifier
50 - Seat (Driver)
