2016 ZX10R Part out....
Goldie
Pics are here: https://postimg.cc/gallery/7h54LvP
Parts are from a 2016 ZX10R. There may be cosmetic blemishes on certain parts and some may need cleaning so see picture link for details or ask me for additional photos. Parts are listed “without” shipping cost (Buyer pays actual shipping). I take cash on local pickup or PayPal (Add 3% if using PayPal). It is “BEST” to TEXT, PM or CALL me if interested at 757-572-4410. Parts are located in Suffolk, VA for local pickup. I no longer race or do track days so I’m selling everything. More parts and stuff for sale forthcoming. Thanks
  • 2,500 Stock Engine with Throttle Bodies, Graves Block Off Plates, NGK plugs (3,366 miles)
  • 1,300 Rear shock - Ohlins TTX MKII KA-931 “Comes with Kyle Racing 0% shock link and extra Ohlins Spring” (Setup for 190 lbs Fast Bike Industries)
  • 1,200 Forks with Andreani Superbike “Gas” cartridges (Setup for 190 lbs by Fast Bike Industries)
  • 350 Front Wheel with Rotors (No spacers)
  • 350 Rear Wheel with Rotors (No spacers or cush drive/hub)
  • 300 Main frame (Has small holes on one side where the fairings mount broke off. Still Structually sound. Come with title that’s not in my name.
  • 260 Gauge Cluster (3,366 miles)
  • 200 Ohlins Mechatronic Steering Damper "Racing" ECU (Converts the Oem Steering damper to a Race steering damper electronically)
  • 60 Ohlins OEM Steering Damper "ECU" control module
  • 80 Ohlins Steering Damper (OEM)
  • 350 Bonamico Rearsets (Complete Kit), Right side needs a foot & Toe peg. Comes with custom "Galfer extended brake line, Quickshifter and linkage, and rear master cyclinder with resorvior delete"
  • 140 Triple Trees (Top and bottom)
  • 160 Subframe (No plastic undertail)
  • 100 Swingarm (Comes with Kawasaki Racing factory chain guard and Bike Master 8MM Swingarm Spools)
  • 300 ECU with "Woolich Racing" software (autoblip, etc...)
  • 100 Factory OEM Wire harness
  • 100 OEM “Titanium” headers
  • 120 Fuel pump
  • 140 Front OEM Brembo brake calibers (Left and right)
  • 60 Rear OEM Nissan Brake caliber and braket (No pads)
  • 100 Gas Tank (Small dent on one side corner) Does not leak.
  • 100 Motion Pro quick turn throttle (Little rash on throttle tube end). Comes with the extra cams
  • 100 GB racing cover set (4 total). Clutch, Alternator and Pulse. Pulse cover has rash and will come with an extra rashed Alternator cover.
  • 10 R&G Racing Passenger Peg delete plate
  • 60 Vortex V2 Keyless Gas Cap
  • 50 BMC air filter
  • 75 Armour Bodies Pro Series “Belly pan” fairing
  • 50 Armour Bodies Pro Series “Tail” fairing. Some rash. Will mount with no issues.
  • 30 Armour Bodies Pro Series “Front Tire" fender
  • 120 Driven Sprockets and EK 3D 520X chain set: 17F/41R. Chain will need a new master link
  • 40 Woodcraft Key Delete
  • 80 Graves Quick Turn Progressive "Throttle Tube" (Design to work with stock housing & cables)
  • 50 Driven Captive Wheel Spacers (Front & Rear wheel sets)
  • 140 Attack "Zero Offset" clip ons with bars. Right side bar is rashed on the end.
  • 120 Radiator and fan and EvoTech Radiator Guard. Has small cosmetic dent. No leaks
  • 100 ZX10RR “Racing” exhaust hanger bracket (Came off the RR version)
  • 200 Grave 3/4 WORKS Cat Eliminator "Exhaust" (Mid-pipe & Can). The muffler has rash but fully functional. Will need a can bracket/clamp.
  • 60 Electronic OEM Quickshifter (This was my spare)
  • 80 Front Brake OEM Brembo Master cyclinder and reservior. Rashed lever.
  • 80 Front EBC racing Brake Pads (Complete set) 90% left ( EBC GPFAX447HH)
  • 50 Clutch Purge with full length "CRG" Lever
  • 50 Driver’s Seat #1 (No Tears)
  • 30 Driver’s Seat #2 (Small tear on the corner)
  • 60 Air Box (No air filter)
  • 10 Coolant Overflow bottle
  • 40 Ram Air intake front. Cracked. Can be repaired with JB Weld
  • 60 Ignition coils (4x)
  • 60 Rectifier
  • 15 Rear wheel axles with adjustment blocks
  • 10 Front wheel axle
  • 15 Front Sprocket cover (Plastic)
  • 10 Tip over switch
  • 20 Front Fairing stay. little rash on ends, but will mount up with no issues.
  • 20 Stock Nissan rear brake pads (80% left)
  • 25 Swingarm “Mud guard”
  • 40 Rear Sprocket hub with Rubber Spacers
  • 25 Plastic undertail (Goes under the subframe)
  • 20 Plastic tank Panels (Left & Right). Some rash on them
  • 30 Plastic Gas Tank Shroud
  • 20 Start/Stop kill switch (Right side)
  • 20 Left side Selector switch (Horn, power mode, etc…)
  • 10 Kick stand switch/sensor
  • 15 AIM solo 2 laptimer Holder
  • 20 Front wheel speed sensor
  • Misc…
  • 100 Pitbull Rear Stand
  • 20 Pitbull Tire Warmers control box stand
  • 20 Trackside Front wheel Stand
  • 30 Harbor Freight Rear Wheel Stand
  • 120 Baxley Sport wheel chock
