2018 Suzuki GSXR 1000R near Bloomsburg PA
Motofun352
2018 SUZUKI GSXR 1000R. Located near Bloomsburg PA
2443 miles, first 300 on the street before converting to track. Have title. Recalled IMU replaced by Suzuki. Race tune by Karns Performance for 93 octane pump gas. Forks and shock extended to 525mm (f) and 324mm (r). 1.05 springs in front when MdM serviced forks last winter. Pair valves removed and block off plates installed. Servo buddy installed to delete exhaust servo and O2 sensor. New plugs 200 miles ago and fresh oil and filter yesterday.
Armor bodies fairing with superbike seat.
Ohlins TTX rear shock
Zero gravity wind screen.
Vortex gas cap.
Tech Spec grip panels
Brembo RCS master cylinder.
Motion Pro throttle tube with variable cable guides
Motion Pro start switch
BMC air filter
Yoshimura Alpha-T SS exhaust
Spiegler SS brake lines
DID ZVM-X rivet link chain
Cox radiator guards
Vesrah RJL-XX brake pads (new)
Suzuki shop manual and owners manual
Woodcraft
  • clip-ons
  • rear sets
  • rear brake return spring
  • brake and clutch lever guards
  • conical frame sliders
  • Stator cover
  • Clutch cover
  • Shark guard for rear chain sprocket
  • Key switch delete/bypass
  • There is cosmetic damage to the right side fairing due to a low side needs minor bondo and local repaint or just ride it like it is. Pirelli slicks (SC2) with 1/2 life remaining installed.
  • The bike has all the modern electronic aids and pulls really hard…just takes a better rider than my old bones. I just had to try a new liter bike with the electronic nannies before I aged out…$ 13,900.
  • Also available are a spare set of blue Suzuki wheels with rotors,spocket and 1/2 used SC1 slick, new Pirelli SC1 200/65 slick, and all the like-new stock take-offs from ABS plastic to head light, turn signals, exhaust, etc for additional $2500.
I do need a spare front wheel with rotors. If you want to part with that separately, just message me.
Thanks,
Nick
