2020 YZF R1
vinny337
Vin is in...Beastmode!
2020 YZF-R1/ 3800 miles/ $19,999/ serious inquires only!
Clean New Jersey Title
Extended OEM warranty until 19 Sept 2025
Stock Motor Dyno Tuned by Bauce (Sunoco 100)
Transmission Undercut and Gears Mirco-Polished (15W/50 oil)
GYTR Wire Harness Assembly
GYTR ECU with Tuning CD
Yamaha CCU Harness/Antenna (no CCU)
Starlane Stealth GPS-4 Lap Timer
Graves ¾ Exhaust (new)
Graves Radiator Cap
Grave Block Off Plates
Custom MDM Shift Rod (shifts effortlessly)
BMC AirFilter
Accossato Gas Cap
GB Racing Case Covers
Titanium Magnet Oil Drain Bolt
Vortex 520 Sprocket Kit
Radiator & Oil Guard
Yamalube Fresh Oil and OEM filter
Ohlins Steering Damper
Ohlins FKR 126 Front Air Forks 1.10 0 miles since serviced
Ohlins Rear Shock 110N 0 miles since serviced
Evol Tech Rear shock linkage
Evol Tech Rear Sets
Jettprime Left and Right Controls
Jetprime Kill Switch
Jetprime Throttle Tube
Safety wired
Brembo RCS-19 (New)
Brembo Clutch Lever (New)
Vesrah XX Pads Front (New)
Spiegler Brake Lines Front & Rear
Fast Frank Semi Quick Change (Adjusters not installed)
Fast Frank Chain Holder
Woodcraft Body Work
Woodcraft Superbike Seat Base
Woodcraft Superbike Lifters
Woodcraft Clip-ons
Woodcraft Bars
Carbon Front Sprocket Cover
Carbon Rear Fender
Carbon Tank Cover
Carbon Battery Cover
Carbon Swing Arm Covers
Powercoated Wheels (White)
Stomp Tank Grips
New Custom Paint Job (R&M)
Fast Frank chain holder
Fast Frank Rear Wheel Spacers
Spares List:
OEM Parts (New)
OEM Oil Filter
OEM Shifter
OEM Fork Bottoms
OEM Front Wheel Sensor (New)
OEM Rear Wheel Sensor (New)
OEM Front and Rear axles
Ohlins Front springs1.05N and 1.00N)
Ohlins Rear 100n and 105n
Front and Rear white powder coated wheels (rear has a slight bent)
Hindle ¾ Exhaust (New)
GB Racing Case Covers (New)
Vortex 520 Front 2 16t/17t (New)
Vortex 44t/41t/42t Rear Sprockets (New/Used)
Vortex Chains 120 & 118 links (New)
Pitbull Tire Wedge (New)
Pitbull Stands Front and Rear
Pitbull Restraint with Pins
Evol Tech Rear Sets Spare parts (New/Used)
Jetprime Throttle Tube (New)
Brembo RCS-19
Fast Frank Semi Quick Change Adjusters
Painted 2nd Gen Tank Shroud
Woodcraft Painted Fender
Woodcraft Painted Tail
Woodcraft Keyless Harness
Woodcraft Superbike Seat Base Pads (New)
Woodcraft Frame sliders
Woodcraft Bars (New)
Woodcraft Bike Stands Front and Rear
Battery Charger for OEM Battery
Shoria Battery Charger (works just needs solder)
There’s more stuff to add, the only flaw there’s a crack on the dash but is fully functional. Bike is quite capable of getting your new PB or placing on podiums. To get ahold of me faster, please text me @ six-zero-nine/six-six-eight/one-six-two-four
Pics
And more
