I was setting the sag on my bike this last weekend. I lifted the front up with a steering stem lift and measured the exposed chrome tube to be 133 mm from the top of the axle casting to the top of the dust seal. I proceeded to set my sage to 32 mm front and 28 mm rear (while in full track gear).
Tonight, I thought I would check the specs on the suspension. The manual states 115 mm of wheel travel for the front.
This got me thinking, does the fork bottom out 18 mm above the axle casting? When monitoring a zip tie on the fork tube, it will be important to know where bottom is.
Thanks!
Thanks!
