$5950 06 GSXR 750 ohlins bazzaz TC QS ZAFM Clear Title low miles
Pascal
06 GSXR 750, ~3700 miles indicated, actual about 5000 (speed sensor failed, replaced)
free and clear title, Never been down, runs perfect, starts right up. no issues whatsoever!
never raced, only track days. Regular oil changes and maintenance.
Solid track bike with a clean history and a clean title. The bike is in awesome mechanical condition. It has never been down (not even the accidental fall at a standstill) Starts right up and runs great - no issues whatsoever.
suspension - ohlins triple rear, GMD built forks and has been setup by Peter Kates @ GMD Computrack Boston. Body by Armour Bodies (the nice signature series). Various protection parts (sliders, case protectors). Full Arrow system, Quick turn throttle (real one, not homemade), clipons, rearsets, quickshift (GP), lightweight chain, sprockets, Giles chain adjuster, etc
and the real gem - full blown Bazzaz System ($$$$$) - traction control, quick shifter, fuel mapping, auto-mapping, all the dash controls! What a difference over the power commander. super smooth, very fast. I had the power commander dyno'd and it never got near what the Bazzaz can do. The Bazzaz system tunes all 8 fuel inctors, unlike the power commanders lower four. Self mapping feature is really cool, just plug in your laptop, tell it to record, ride a session, plug in the laptop and it will recommend on how to re-map the fuel injection (no more Dyno runs! change fuels, temp, velocity stacks - just re-map and save). Quick shift and traction control are also adjusted via a laptop. just plug in and adjust. With he dash controls you can switch between two maps while riding. There is also a rotary switch for adjusting the traction control based of the traction map you configured. You could easily use the self-mapping feature to create maps for cold weather, wet, hot weather and so on. Very easy to use!
and of course spares! levers and lots more!
Will consider trades+ cash for the following:
Arai Haga replica small
08 Aprilia RSVR exhaust with removable baffles (must be clean)
Coral Reef fish tank stuff:
-- 120 rimless 4 foot tank
-- sump
-- frag station
-- dosing pumps
Performance
--Bazzaz Fuel management (complete system - TC/QS/Self-Mapper)
--Fuel management module
--Clipon mounted fuel map switch
--Quick Shift (with reliable version of shift sensor)
--Traction Control
--Clipon mounted Traction control dial
--Self mapping module with wide band lamba sensor installed onto Arrow exhaust
--BMC Air Filter
--Full Arrow Exhaust
Suspension
--Ohlins Triple sprung for 180Lb rider
--GMD Built forks .95 spring rate
--Chassis Computracked
--Frame Confirmed straight by computrack
Braking
--SRJL pads with good life left on them
--Stainless steel lines front
--Stainless steel lines rear
Drive
--Giles Chain Adjuster
--Vortex Front Sprocket
--Vortex Rear
--DID lightweight chain
Controls
--Woodcraft ClipOns
--EuroRacing Quick Turn Throttle
--Renthal Medium Grips
--Vortex RearSets, set for GP Shift
--Shorty Shift lever
Body
--Armor Bodies Signature (the expensive ones)
--Italian aluminum fairing stay
--DZUS fasteners
--Paint not perfect, but pretty good (takes great pictures!)
Protection
--frame sliders with replaceable mushroom pucks
--tied down attachments for frame sliders
--Moto-R Alternator Cover Guard
--Moto-R Clutch Cover Guard
spares
--spare clip on tube
--extra set of frame slider mushroom caps
--vortex front sprocket
--sprocket cover (left over from replacing speed sensor)
--stock throttle cables
--seat release with same key
--shift rod
--windscreen
--stock exhaust (header and pipe)
--spare swingarm
--rear seat
--set valve with cables
--stock fork parts
--rear brake switch
--odds and ends (bolts, mounts, etc) - most in labeled zip lock bags
$5950
I understand everyone is tight on money so I'm willing to work with folks to make it happen.
extra stuff for sale not included
-- ohlins steering damper
-- brembo MC
-- Extra set of rims with Rain Tires
-- two sets of wave rotors
-- lap timer with long and short cord
-- quick turn fuel cap
-- extra cush drive with new vortex sprocket
**wave rotors and pit b**ch in picture not included**
**lap timer in picture not included**
Pascal
all in great condition:
* ohlins damper 225 shipped
* wave rotors (front and rear) - have two sets - miced the first set at .204" - can't even feel wear on them. Other set is hard to get to right now. $380 shipped per set
* front and rear rims (no cush) with oem rotors and rain tires in great shape (little use, two years old) - usual nicks from tire changes $500 + shipping
* cush drive with brand new 45 tooth vortex sprocket $55 shipped
Pascal
mix and match parts and make reasonable offers. There have been a lot of requests for transportation. I will move 2 hours any direction, however I can not cross the Canada border as my passport is expired. The title is CLEAR and paid off.
$5900 GSXR750 with free and clear title (as lsited)
$50 cush drive with brand new vortex sprocket
$350 full set of wave rotors (front and rear, no installed)
$350 full set of wave rotors (installed onto spare rims)
$500 spare rims with *rain tires* that look almost new
$150 Factory Pro velocity stacks (like new - not installed) (http://www.factorypro.com/Prod_Pages/prodS78,gsxr750,06.html)
$0 OEM rotors for spare rim
$0 NEW extra vortex front sprocket
$0 NEW vortex replacement clipon tube
$0 NEW set of mushroom sliders
$0 two additional cams for quick turn throttle
USED OEM parts:
OEM exhaust
OEM Header
OEM shock
OEM clutch lever (shorties installed)
OEM brake lever (shorties installed)
OEM shift rod with linkage
OEM axle blocks
OEM extra set of wheel spacers
OEM set valve
OEM set valve cables
OEM case bolts (from installing Moto-R cases)
OEM engine bolts (from installing frame sliders)
OEM passenger seat mounting bracket
OEM rear seat release with key (same as ignition)
bodywork:
rear brake and signal wiring harness
rear brake switch wiring harness
Headlight cable (needs to be spliced back on - I believe this is the high-beam cable which I used to power a video camera)
OEM windshield (normal use scratches)
misc:
misc bolts from OEM parts removed
fairing bolt set (from removal of OEM bodywork (I believe this to be fairly complete, but cant guarantee it)
extra nuts and bolts from gilles chain adjuster
Pascal
Sale for next weekend fell through, same offer - $200 off the bike.
Headlight wiring that was cut is 2 wires, very easy to re-attach
PJZOCC624
If you're looking for a good deal on a SOLID 750, this is your bike!! Pascal is quite possibly the most anal dude I've EVER seen when it comes to his stuff!! Good luck with the sale!!
Nexus
how much for those and any stock rearsets? Or want to sell the Ohlins shock?
Pascal
For now Id like to keep the spare levers with the bike and the Ohlins shock. This is a fully setup track bike with some spares - turn the key - put on your gear and roll.
If someone wants the bike without the shock i will put the factory back on and drop the price.
Thanks PJ - It is an awesome machine in awesome shape. Full appreciation comes after the throttle is turned :)
