Sig fixed!
I don't
think the Ducati swingarm is bent. Tonight I tore the whole friggin thing down, enough to get better measurements from the frame to the axle. Before I was measuring from the end of the vortex rearset pegs to the axle - only things sticking out far enough to get a clean line on.
The thing is..it turns out my left rearset is mounted in a different position than the right side, to allow the gp shift bar to clear. Also, the right side rearset mounting tabs are bent to hell and gone from crashing on that side a few times, making the peg stick out at an angle.
(Yeah I'm a dumbass)
Anyway....
Once I took all the BS that was getting in my way off the bike, I measured from 4 different spots on the frame on both sides, it's even.
It's all REALLY clean back there now. I found out my chain wasn't black.. it's silver? I also figured out how to adjust my chain. Kind of easy, really. Just loosen two big bolts, grab a screwdriver & hammer, and bang on the eccentric. The manual calls for 33-35mm (measured from swingarm), I set it at 40mm since "We're not riding the street, yo!"
I'm stoked.
Ordered levers tonight, tomorrow after work it's getting drilled & safety wired, epoxy the tail section back together. Then Thursday it's getting put back together. Hopefully it'll pass tech.
Also tomorrow I'm turning a set of spacers for the gixxer on my lathe in the garage, and mounting those monoblocks up.
Gotta go fast... gotta go fast..
