RADAR Magnet
I'm interested in getting a bleeder and looked at the Mity vac but there are a bunch of different versions. Anyone have a recommendation for one that works best for bikes? Thanks.
Actually, I couldnt agree more. The tools are very useful for setting up a dry system, but for easy bleeds and fluid flushes, this cant be beat. I have the same on my track bike and come to think of it, I dont use any vacuum bleeder on it ever. Crack em open, pump til your heart's content, and tighten them back up.Thunderace;277546 wrote: Don't bother with a Mighty Vac or any other bleeder mechanism. Buy yourself a Speed Bleeder for each caliper and your done.
I've had the speed bleeders on my front calipers and the rear for about a year now, no issues. When the brake system is not dry i use the mity vac but everyother time it's just the tube and bag that i linked up. Takes a whole of about 5min to completely bleed the brakes to where it's perfect. Speed bleeders definitely the way to goRADAR Magnet;277570 wrote: I guess I'm a little wary of speed bleeders after reading threads about air getting in through the threads and having to apply tape or grease to prevent. I can do that but was thinking something like a mity vac would be a better solution. Not so?
:agree:Thunderace;277546 wrote: Buy yourself a Speed Bleeder for each caliper and your done. At $7 a piece, they are completely worth it. I have a Mighty Vac that I have in my trailer, but it hasn't seen daylight in 4-5 years. All you need is a hose and a water bottle to bleed your brakes. Just so you know, they have a little spring inside with a ball bearing that allows you pump the fluid out without air getting back in. They look almost identical to your OEM bleed screws.
Best $7 purchase bar none I have made for a motorcycle.
No worries at all using them. I've had them on my bike since 2008 and I have never had a brake issue because of them. The key is to just barely loosen them when bleeding. I normally apply pressure to the lever as I loosen the bleeder until I feel it start to flow. Pump the brake until I've run a couple reservoirs through the line, then tighten it back up. My lever is extremely solid when done.RADAR Magnet;277570 wrote: I guess I'm a little wary of speed bleeders after reading threads about air getting in through the threads and having to apply tape or grease to prevent. I can do that but was thinking something like a mity vac would be a better solution. Not so?
:agree:HondaGalToo;277724 wrote: MityVac is useful if trying to get fluid flowing through dry lines, that's about all it's good for. Even so, you then need to follow up with a "traditional" bleed. The Speedbleeders make the job easier. I've used them for years with no issues. I've heard that air can get thru the threads. The threads have some sort of coating. If that does become a problem, they sell the stuff so you can "repaint" them. I wouldn't use tape or grease.
Thunderace;277703 wrote: No worries at all using them. I've had them on my bike since 2008 and I have never had a brake issue because of them. The key is to just barely loosen them when bleeding. I normally apply pressure to the lever as I loosen the bleeder until I feel it start to flow. Pump the brake until I've run a couple reservoirs through the line, then tighten it back up. My lever is extremely solid when done.
I'm not saying that people haven't claimed or had problems with air leaking into the braking system. But, it seems like you would see the brake fluid coming out before you would have air going in. The positive pressure in the caliper is much greater than the negative procedure. I'm not saying it doesn't happen but I would be extremely skeptical.RADAR Magnet;277570 wrote: I guess I'm a little wary of speed bleeders after reading threads about air getting in through the threads and having to apply tape or grease to prevent.
SB7100S M7 x 1.0 1.19 (30.22)RADAR Magnet;278077 wrote: Ok, you all have convinced me. But I went to pick up a set and saw that some sites require me to specify the size and thread pitch info while others do not. Do I really need to find the thread info (doesn't seem easy) or can I just select Honda and wait for them to arrive?
