stephenjpauls
All,
I feel like I'm doing something wrong, and was hoping someone could give me some insight on what I should be doing...
I took my calipers off my bike, took them apart, replaced all of the seals and the dust covers after cleaning everything up. Since then I have been working on bleeding my brakes. I have pumped the brakes over 1000 times, after that didn't work I started to bleed them figuring the issue was that there was just too much air in the system and I had to get it out before anything would work. So I have been pumping my brakes then open the bleeder valve while holding the lever in, close the bleeder valve, release the brake lever and start pumping again. As I have been doing this, I'm to a point that the fluid is coming out (dribbling out, not squirting) and there does not seem to be any more air in the system (I have a clear tube attached to the bleeder and I don't seen any bubbles in the fluid coming out). There is just enough pressure when the brake lever is all the way in to stop the wheel from spinning. So I decided to ask a question here to see if there is something I'm doing wrong.
This is the stock calipers and stock master cylinder on a GSX-R600. The brakes were working well when I took the system apart... I just wanted to make sure that everything was clean which is why I did the rebuild.
Thanks for your help,
Steve
Steve
