tankslapper
I got a clutch lever replacement and it came with no bushing. Stock busing does not work as it is too big to fit in mounting hole. For those that have replaced clutch levers with something other than stock, does new lever come with bushing or do they drill hole same size in lever so you can use stock. Maybe the Chineese knock-off part makers forgot about this and drilled hole in their lever too big.
