Off I go to buy another frontrk97;210438 wrote: I run Q2's in Advanced.
I tried those pressures and they stuck like summer car tires in an ice skating rink. One of the CRs recommended lower hot pressures and they have been golden ever since. 6 Days so far, and probably a few more in them.daddyfriedrich;210990 wrote: The Dunlop guru told me to use 32/32 cold on Miss Paula at VIR North in June, ambient temps around 95. They stuck like friggin velcro. I'm a believer. I'm also a bona-fide B group back marker, unless someone else has noticed me passing them???
Noted. Assuming my pace improves, the rear I have on there now will probably be my last before moving on to 209's or 211's or something.rk97;210907 wrote: ^ I wouldn't suggest them as a long-term solution for an advanced pace, but they will get you into "A" group.
At higher speeds, you just have to be more diligent about adjusting pressures, and you can't make bonehead mistakes. I pushed the front pretty badly after chopping the throttle at apex. My fault; not the tire's. And like any tire designed for some street use, they can overheat in extreme conditions. I usually start the day with pressures at 30/30, and when they start feeling a little greasy, I up the (cold) pressures 1-2 lbs to keep them from flexing so much. Might be all in my head, but it seems to help. usually I only have to adjust the front.
Obviously, you gentlemen have not ridden with me. I use a sundial for my lap timer. It even works on rainy days!daddyfriedrich;210990 wrote: The Dunlop guru told me to use 32/32 cold on Miss Paula at VIR North in June, ambient temps around 95. They stuck like friggin velcro. I'm a believer. I'm also a bona-fide B group back marker, unless someone else has noticed me passing them???
BigBird;211268 wrote: I tried those pressures and they stuck like summer car tires in an ice skating rink. One of the CRs recommended lower hot pressures and they have been golden ever since. 6 Days so far, and probably a few more in them.
You probably have passed me daddy
Definately did not work for me. Way too much pressure for my liking. I was told the same thing, set them at 32 and leave them. Well after my first session I was sliding all over so I came in and set them to 30 hot front and rear on the warmers and have't gone with anything different since. Great tire to get you into A pace, but may want a little more to be running up front indaddyfriedrich;210990 wrote: The Dunlop guru told me to use 32/32 cold on Miss Paula at VIR North in June, ambient temps around 95. They stuck like friggin velcro. I'm a believer. I'm also a bona-fide B group back marker, unless someone else has noticed me passing them???
6 days at the track on street tires!BigBird;211268 wrote: I tried those pressures and they stuck like summer car tires in an ice skating rink. One of the CRs recommended lower hot pressures and they have been golden ever since. 6 Days so far, and probably a few more in them.
It's definitely possible. When I first came to the track I had a set of michelens with 8k street miles on them.... And they lasted me like 5days at the track. Hell I have 6 days on my 211gpa rear now (but its toast).HaVoC;219305 wrote: 6 days at the track on street tires!
