Will the front calipers off an 08 gsxr 750 fit an 04? Same brand, just different color.
mike27 New Member May 16, 2012 #1 Will the front calipers off an 08 gsxr 750 fit an 04? Same brand, just different color.
Otto Man John Control Rider May 16, 2012 #2 Most jap bikes have 108mm bolt hole spacing...so assuming the rotors aren't different diameters...you should be a-ok. However, it sounds like something a gixxer forum would know for certain.
some guy #2 Member May 16, 2012 #4 The calipers will fit. It's a straight bolt on. There's no performance advantage if that's what you're after.
D-Zum My 13 year old is faster than your President May 16, 2012 #6 So get R6 calipers and improve performance while you're swapping. They're WAY better for stopping power and 100grams/caliper lighter.
mike27 New Member May 17, 2012 #7 I'll check into a set of the R6 calipers. So what years of those will fit? Or will any of their radial type fit? Thanks guys
