Front Fairing Stay
bahs
Anyone recommend torching the fairing stay to bend it back in place? Or is it better to get another? If so, can you recommend a site or shop. I am Ga and I have a '03 zuk 1k. Thanks all.
Since you bent it I guess its an aftermarket stay which would be make of aluminum. You should be able to bend it back without a torch.
Try bending it back first. If it doesn't break you should be fine since it isn't a structural piece. Aluminum does cold work and depending on how far it has bent and the type of aluminum, it may break when you try to bend it back.
