How does 1st-5th work at Road Atlanta with the back straight?Gorilla;243854 wrote: Depends on if you use 1st-5th or 2nd-6th but stock is a good place to start.
If you gear it to where you can use 1st out off T7 & 12 you won't need 6th before your on the brakes for 10astow;244178 wrote: How does 1st-5th work at Road Atlanta with the back straight?
I'm with Vinny... -1 front and +2 rear seems to work out perfect there for me there. I run out of gear on the back straight, just as I'm ready to grab the brakes.vinny337;244160 wrote: I think I'm going to get a feel for the 1-F/2+R seems to be the weapon of choice, I've never been there so it will be a learning experience.
What would the advantage be for gearing it this way? I understand how it can be done, but not sure why.Gorilla;244397 wrote: If you gear it to where you can use 1st out off T7 & 12 you won't need 6th before your on the brakes for 10a
Running 17 43 on my 08 Suzuki 1000 I use 1st in 7 & 12some guy #2;244406 wrote: T7 and 12 are not 1st gear turns unless you are on a smaller bike. I could maybe see coming out of 12 but def. not 7.
