I'm in the Nanuet area. The symptom was that the bike, after running well, very quickly started running roughly and was lacking power. After being questioned about the year make and model, I was told that the culprit was likely (if I recall, something like...) the sub throttle assembly or sub throttle body or something to that effect. Apparently it's a known problem with the bike I have. His explanation was that the gears on the throttle servos are plastic and they break or strip or something and exhibit the symptoms I described to him. Anyway, the idea is that I need to take off the air box and with the battery connected, turn the ignition on and observe the throttle valves. They should open and close smoothly on power up. If the throttle valves don't open and close, or if they operate roughly the throttle bodies will need to be replaced.
