RADAR Magnet
I don't like the look of my stock grips and bar ends; have done a bit of surfing on alternatives but thought I'd come out here and see what opinions are for each. Which grips/ends do you guys like or dislike?
Good point about the clearance. I seem to recall that Hondas may have those issues, not sure which models. Check with Woodcraft, for some clipons they have additional products, such as risers, etc. for certain bike models with clearance issues. At least I think so, check their website.Meat;301295 wrote: Check the clearance between the upper fairing and the new clip-ons and cables and hoses. Some bikes will need modification did to the clip-ons being a little farther forward than stock.
I have Graves on this bike, I had Woodcraft on my last bike.
I like the Renthal medium density grips because.
Using an air compressor with a blow gun attachment makes installing grips a breeze. If you need to, spray the bars with soapy water. Makes it easy to install, and will tack up nicely once tried. Others also use hair spray. Quick safety wire on both ends of the grip after installation, and you're ready to rock.RADAR Magnet;301402 wrote: Thanks guys, this is helpful. I actually have a set of Woodcraft clip ons that I've had laying around in case of an accident. I think I'll just slap some new grips on them (I was also leaning toward Renthal) and put them on the bike. Not having done that before, I'll be back with more questions later...
HondaGalToo;301427 wrote:
When you install the clip-on bar on the throttle side, you'll notice a "nub" on the throttle housing that fits into a corresponding hole or slot on the OEM bars. That "nub" keeps the throttle housing from rotating. Measure and drill an appropriate sized hole in the clip-on bar to accommodate the housing "nub". Some have just used some grip tape, but I think it's safer to drill the hole, to be sure the housing won't rotate.
Hahhaha!!! I got Aquanet unscented.Meat;301476 wrote: And I use cheap hairspray as well. I swear when I bought it everyone was thinking "bald man buying hairspray"....poor guy.
Initially, I dremeled the nub off. Then the more I read, the more I decided that was a bad idea. Plus the throttle housing was moving just a bit. So, I got a small screw, put it in where the nub was, cut off the screw head and dremeled to the correct height of nubliness, and viola! New nub. It's held up for several years now and survived a couple of crashes.Meat;301475 wrote: Excellent advice. I forgot about that one because I've usually switched to aftermarket clip-ons after a crash and the motorcycle gods seem to like eating that little nub on my first impact.
..but...I have a Suzuki...Otto Man;301502 wrote: I must admit, I grind that nub off. But I've never had a problem with the throttle housing rotating. Must be a Honda thing.
