Parts off a 06 gsxr750, many will fit other years/models. Parts are used and in good condition unless otherwise noted. I have detail pictures of everything listed that I can send upon request.
Aftermarket:
Driven front sprocket (16/525) $10
Swingarm spools $5
Stock:
Gauge cluster backplate (backplate has been modified but still mounts properly) $5
Throttle cables $5
Misc parts (throttle tube, rad cap) $5
Drilled oil drain bolt $5
Bent forks $20
Radiator reservoir $5
Oem front/rear sprocket set $10
SET valve and cables $5
Aftermarket:
Swingarm spools $5
Stock:
Throttle cables $5
Bent forks $20
