JayhawkInDC
Alright, so after spending the weekend working on the bike, I cannot get it to start. It will crank (although the battery is low on power), the fuel pump is working, and it started just fine last week before I started messing around with it.
I had the airbox off, but replaced all of the connectors and hoses appropriately, I had the fuel tank off, but connected the both the fuel line and the fuel pump connector properly. As I said I checked the fuel pump and it is spewing gas correctly.
Beyond the battery and the spark plugs, what else do I need to try? Is there anything in the wiring harness (from the dash connectors (white, yellow and black forward) that I could have screwed up that would still allow it to turn over but not fire?
Any suggestions will be much appreciated!
