Last weekend at Heartland my F4i cut out coming into Turn 8 which it hadn’t done before. Then, after lunch, it freaking did it again. It was idling low so I cranked it up thinking it was dieing when I shut off the throttle quickly, but it freaking did it again!
Obviously this was a recipe for an asspacking. Fortunately, a spectator saw the last episode and knew exactly what was going on. His diagnosis was right on - the bank angle sensor was flopping around behind the dash. With some creative zip tying I locked the POS to the fairing stay and didn’t have the problem again. My dilemma now is what to do going forward.
The designers at Honda should be slapped for mounting such a crucial component to the headlight. It’s a freaking trackbike you morons! There are no headlights on trackbikes!
Anyway, I don’t see a good place on the fairing stay to bolt the thing that would keep it horizontal from the sides and front. Quite honestly, I’d rather keep it to prevent the motor from grenading in a layover, but only if I’m certain the cut-out problem’s solved.
I was up late last night Google searching the issue. It looks like 929’s and 600RR’s have the same setup. The 600RR guys are lucky in that there are two spots on the fairing stay to tap in to. The stunters just cut 'em out, splice the green and red wires (?) and leave the white open. What do you guys do?
