Hoppa's 04-07 CBR1000RR Parts Bazaar
hoppa2k6
Dan Kyle / HRC Full Race ECU 04/05 - $350 shipped
Hunter Orange Fairing Stay - $120 shipped
Hunter Orange Aftermarket Stator Cover - $120 shipped (OR $200 shipped for matching Fairing Stay and stator cover)
Has small mark on it (pictured)
OEM Stator Cover - $50 shipped
Small marks
Rectifier - $40 shipped
Dynojet PCV - $210 shipped
Bazzaz GP Shift Quickshift Sensor - $200 shipped
Bazzaz shipped me a new head unit and sent a newer quick shifter with it when replacing my broken head unit so I have two quick shifters now.
Ohlins Titanium Spring - $300
Fits NON-TTX Ohlins Shocks. Sprung for lightweight rider. ~150-165lbs
Sharkskinz Supersport Tail - $200 shipped
In near mint shape (in the pictures, there looks like some damage, but it's just some weird flash glare), this tail was painted with a custom dark red metallic on black. You can't see it in the photos, but get the tail out in the sun and it pops. Tail currently has a functional tail light for street riding; however, two holes were drilled in the tail for track riding (lap timer).
Metallic Dark Blue-ish Black OEM Honda Seat Cowl (some scratches) $50 shipped
Barnett Clutch Kits - $100 each
Includes Springs, Fiber plates, and Steel Plates. I oiled one set up when I was going to install a set into a friend's bike but he ended up not wanting to do the install because he found a new bike and sold his. Both kits are brand new tho.
Blue and Yellow Tank Shelter with Carbon Fiber Inserts
Great Condition. Comes with CF look tank pad. Will not part out the inserts, they are epoxied in place.
$160 shipped
Near mint headlight. Has all tabs! - $150 shipped
Riders seat - $50 shipped
Subframe - $150 shipped
Rear brake with lightened bracket - $50 shipped
Rear brake with bracket (x2) - $45 shipped
White Aftermarket Clutch and Rear Brake Lines with purple banjos - $50 shipped
Blue Aftermarket Rear Brake Line - $35 shipped
Heat Exchanger - $40 shipped
Race Upper Harness (x2) - $40 shipped each
Blue Lightech Keyless Gas Cap - $80 shipped
OEM Horn - $20 shipped
Oem Shock Linkage (x4) - $40 shipped each
Radiator Brackets (x3) - $20 shipped each
OEM Rotors - $35 shipped each
Wave Rotor - $100 shipped
Tank Inserts - $15 shipped each
Upper and Lower Fuel Rails - $30 shipped
Hyperco Spring - $50
Spring would work great for a 250lbs rider.
Ohlins Spring (like new) - $80
Spiegler Aftermarket Black Clutch Line - $50 shipped
Kill Switch (x2) - $25 shipped each
Steering Dampner Mount - $20 shipped
Axle Adjusters - $15 shipped
Trunk and Gas Cap Lock with one key (no ignition) - $80 shipped
Ignition and trunk lock set with two keys (no gas cap) - $80 shipped
Ignition Lock with one key - $60 shipped
Trunk and Gas Cap Lock with one key - $80 shipped
Stock Passenger Rear Pegs Mint Shape - $50 shipped
Turn Signal Flasher Relay - $25 shipped
Stock Rearsets (need pegs) - $40 shipped
Radiator Fan - $40 shipped
Sprocket Cover (x2)- $30 shipped each
Axles - $20 shipped each
Aftermarket Reservoirs - $25 shipped each
Side Inserts - $30 shipped
Right Side Rearset (needs peg) - $30 shipped
Rearset Heel Guards - $20 shipped
OEM Stock Levers (light rash) - $20 shipped
OEM Stock Levers (clean) - $35 shipped
Stock Rear Brake Reservoir - $20 shipped
Block Off Plates - $30 shipped
Kickstand (with wiring) - $25 shipped
Kickstand (no wiring) - $20 shipped
Sato Rearset parts - $25 shipped
Vortex Rearset parts - $25 shipped
Stock Brake and Clutch Master cylinders with Aftermarket Adjustable Levers - $200 shipped
Clear Stainless Steel Aftermarket Rear Brake Line - $30 shipped
Galfer Rear Brake Line Kit - $30 shipped
OEM Clutch Slave (x2)- $20 shipped each
Gilles Shift Support - $100 shipped
Cush Drive Rubbers - $20 shipped
OEM Cush Drive with Aftermarket Sprocket - $50 shipped
OEM Cush Drive with Aftermarket (Renthal) Sprocket - $50 shipped
OEM Cush Drive with Aftermarket (Red) Sprocket - $50 shipped
OEM Cush Drive with Stock Sprocket - $50 shipped
Upper Triple Clamp - $50 shipped
Brand New Chrome Stator Cover - $50 shipped
OEM Headlight/Tach Harness - $30 shipped
Radiator Hose Splitter - $15 shipped
OEM Black Shifter Lever - $20 shipped
Plastic Battery Tray - $40 shipped
Heat Shield - Free with any other purchase!
Air Funnels - $20 shipped
Front and Rear Axles - $20 shipped per axle
Laptimer Beacon - $50 shipped
Here is the same list with pix:
Small marks
4 cell Speedcell Battery - $80 shipped
$160 shipped
Subframe:
