something that can carry 2 bikes... Was looking at a 6x12 V-nose. As for price range, 3-4kNesba;166609 wrote: What are you looking for? Size, price range?
Curious. What will be your tow vehicle?rxpusher;166680 wrote: something that can carry 2 bikes... Was looking at a 6x12 V-nose. As for price range, 3-4k
2003 Toyota Prius. think that it can tow a enclosed trailer... :notsure:Fastguy;166719 wrote: Curious. What will be your tow vehicle?
With the Prius, you'll get great gas mileage while towing that trailer.rxpusher;166727 wrote: 2003 Toyota Prius. think that it can tow a enclosed trailer... :notsure:
I'm towing with a 2007 Acura MDX actually.
5000 lbs, they upgraded it when they put out the 2007 model.HondaGalToo;166758 wrote: Actually, what's the tow limit on the MDX? I'm thinking you'd be pretty close to it...definitely look into a lighter, aluminum trailer.
That would've been my guess. See what the curb weight of the trailer is, plus 2 bikes and all your gear. You don't want it to be close to 5000 lb, the max tow weight of your vehicle, as there's other things to consider, like wind drag. The tow rate on my truck is 9000 lb, but I'd never attempt to actually tow 9000 lb with it...rxpusher;166798 wrote: 5000 lbs, they upgraded it when they put out the 2007 model.
yeah, I hear you, the thing is that the max hitch they make for a MDX is a class 3, which is only rated to 4000 lbs. the featherlites are nice, but at 6k, it's a bit outta my range at this point.HondaGalToo;166801 wrote: That would've been my guess. See what the curb weight of the trailer is, plus 2 bikes and all your gear. You don't want it to be close to 5000 lb, the max tow weight of your vehicle, as there's other things to consider, like wind drag. The tow rate on my truck is 9000 lb, but I'd never attempt to actually tow 9000 lb with it...
I used a trailer in a bag for 2 seasons and it served me very well despite all the abuse i put it through, towed it with a yaris!:wow:ct1200;183152 wrote: I just bought a Trailer in A Bag.
Not used it yet but I did put it together.
Seems pretty good to me, best thing is when I'm done, pull it apart and store it inside.
And if you are in NYC, that might be a big + for ya.
Going to be towing with a Mazda so I need as light as I could get.
The condor is awesome, made my life much easier when i added it to it.ct1200;183182 wrote: Ya had to do the Condor, can't see y not, takes most of the issues out of play.
And I got the 2 bike version just incase someone might want to tag along, or even a Daytona trip someday.
For any apt ppl this thing is great.
I have a few ideas on adding like a truck tool box to carry a few items.
An a good cable lock will help with security, but those who really want it will take it.
Thx for the info tho!
Why, the vehicle is rated for the weight and is built with a margin of error for safety. the manufactures warranty there vehicles to tow this amount and would not do so if it was not capable of doing it safely. Also wind drag is almost the same if your trailer is 1500 empty or 5000 lbs loaded, the walls on an enclosed trailer produce the same resistance.You don't want it to be close to 5000 lb, the max tow weight of your vehicle, as there's other things to consider, like wind drag. The tow rate on my truck is 9000 lb, but I'd never attempt to actually tow 9000 lb with it...
