Just stumbled into this on the Superbike mag website. What a simple yet effective idea. Should beat the old toe lift/spacer pop-out/swearing method.
http://www.pitstoppal.com
Yes, you should have. :banghead:Steve;49970 wrote: I knew I should have patented that idea, :doh:
:agree: and it was,nt to hard to makedale.b;50472 wrote: Dude, its almost as good as the block of wood I invented.
i just skip right to the swearing partninjamansc;49956 wrote: Should beat the old toe lift/spacer pop-out/swearing method.
Damn I knew I should have patented that!dale.b;50472 wrote: Dude, its almost as good as the block of wood I invented.
Same here. I always just stare at the rear wheel laying on the ground for a solid 30 seconds or so knowing its going to be a joyous time. It never disappoints.lemondrop;50647 wrote: i just skip right to the swearing part
I thought you invented the socket methind???dale.b;50472 wrote: Dude, its almost as good as the block of wood I invented.
and a 5th to hold some slack in the chain.physicistkev;50775 wrote: Now, I just need the third hand to hold the rear caliper and the fourth hand to hold the spacers in place.
