Marchesini rim R1/6 99-03
snikwad
1 USED alu marchesini 5Y front rim, for 00-03 R1. should fit R6 too
no rotors, complete with spacers.
wasblue, powdercoated white. 1 single chip, inside rim where tire bead sits.
asking $530 shipped. obo
Here's the deal, i bought it to try to retrofit it to my 06 R6V, but i failed to see that the older R1/6 used 6 bolt rotors, not 5 like the newer ones.
I have test fitted it to my R6V and it fits perfect, SO, if you have oversized pre 04 R1(6 bolt) rotors, that are 320mm you can run this on a new R6 with 5mm spacers at the calipers. but mounts should be machined down 2.5mm
If you have 310mm pre 04 rotors (6bolt) youre golden.
If you have a 00-03 R6 or R1, these will bolt on fine and use stock rotors.
Im still attempting to get a Marchesini accessory kit so i can make it fit my R6V, but no luck so far, finding the carrier that holds the bearing. TAW has a rotor carrir for it but its the newer style that doesnt carry the bearing.
