07/08 1000 Misc. Stuff f/s
Have a few misc. things laying around that need to be moved out. Rims in the first picture are not for sale, only the second one.
Stock shock- Less than 2500 miles on.
Stock front brake pads- Full set (Tokico HH pads)
Rear wheel, slightly bent, easy fix (wills rim repair, will come with cush drive)
Stock front calipers- less than 2500mi
Rear swingarm- Good condition, no scratches, have chain gaurd and hugger (needs bearings, have the spacer)
DID VM3 gold chain-110 links 530 pitch, great condition 500 miles on it
Armour bodies front fender- bright ass yellow, good condition
Sprocket specialists rear sprocket- +1 from stock, shows a little wear
Front rotors- Machined by true disk- off an 07 600 but will fit the 1000's too.
Stock body panel- orange, piece under the right hand grip (ram air cover)
Make an offer if you're looking at something.
If you would like pictures they are up here:
http://www.gixxer.com/forums/showthread.php?t=324961
