Meat
I have always had major problems with getting the Motion Pro clutch tool to hold the clutch hub in order to get the nut that holds the clutch basket off.
I ended up ruining the clutch hub on a donor motor, and then have messed up the hub on the motor that I am trying to work on (ordered new hub already). I just don't get it. I put the tool on and it just flies off soon as serious torque is applied to the hub nut. I end up really cranking the tension up on the tool and nicely mangle the hub.
I don't have many attempts left as the hub nut is getting rounded. I will also need to install the new clutch hub.
Attached is a pic of how I am using it. There must be a better way to use this tool, or a better tool. Can someone please give some suggestions. BTW: I did order an impact wrench to help out.
