NJMP 4/30
g_debell757
April 30th @NJMP will be my first trackday. Just picked up a 2012 ZX6R thats in fantastic condition. New to sportbikes, coming from dirtbikes(trail riding). Protective gear is in the works. I have a canopy, tools and such for the day. Any suggestions on something that gets overlooked and/or forgotten about??? Looking forward to meeting some new people and gaining knowledge. Thanks in advance.
Don't forget your BIKE KEY! I've seen that happen too many times because it's not being ridden to the track.
Water and an electrolyte supplement of your choice, and food/snacks.
Extra gas, although it is available for purchase at the track, but $$$
Tire gauge, you'll want to lower your cold pressure.
air pump/compressor
chairs/table
Don't forget to put your number on your bike, large enough and good contrast to be readable by the corner workers
Have your chain on the looser side of the adjustment range.
That's all I can think of off the top of my head.
Welcome! See you there! I'll likely be coaching in Novice!
air pump/compressor
chairs/table
I just registered for the event as a novice. Am I required to purchase a membership or can I do that after my first trackday , if i like it?
Welcome! You'll love that Kawasaki.
This is an old list of mine that may give you some ideas. The things I ensure I have before I roll are bike, key, & gear. I sometimes throw in spare gear just because you can't get on track without all of it (maybe a note for later, once you're hooked...like we are).
This older list isn't complete for me. Not all of these are good ideas, they're just ideas. :)
Power cord for fan and warmers
Mobil 1 15W-50 Oil
Tire thermometer
Cable ties
Safety wire and pliers
Two mirrors
Plastic bag w/
Scotch-brite
Earplugs
Two Sharpies
Toothbrush for cleaning
Pen
Utility knife
Box cutter
Boot heel screws
Valve stem tool
Service book
Rags
White ruler
Flat screwdrivers (5-6)
Phillips screwdrivers (4)
Metric Allen wrenches, sockets, loose, and fold ups, and large 12/14/17mm sockets
Adjustable wrenches (3)
Handle 3/8 socket driver
¼, 3/8, and ½ ratchets
¼ and 3/8 extensions and elbows
Socket drive size changers
¼ and 3/8 racks of metric sockets
3/8” sockets- 5/8, 5/8 spark plug
½” sockets- ¾, 13/16, 22mm, 7/8, 15/16, 27mm, 32mm impact
8, 10, 12, 14, 15, 17mm wrenches
Needle-nose, cutting, vice grip, and regular pliers
Robo-grip pliers, wire strippers
Awl
Flashlight
Suspension adjustment tools
Plastic Tub
Tire pressure gauge
Electric Meter
Rubber hammers (2)
Two torque wrenches
Plastic bag w:
duct tape
electrical tape
sunscreen
pen/paper
gas can cap
syringe
tape measure
JB Weld
Never-seize
They're the best. I've learned to cut off the rounded inner end just a bit. This let's them apply additional friction and the outer ends to go in a little further. That way, the helmet install doesn't knock them out. One of those beanies I used to think were silly also helps with that.
I think the most important thing to bring to your first track day is patience with yourself.
That doesn’t mean a lackadaisical approach. Instead, it means recognizing the pace at which you can understand the instruction will probably be much faster than you can translate that instruction into consistent actions on the track.
It takes time to:
a) know the track,
b) get your eyes up,
c) be smooth on inputs, especially brakes and
d) execute all the various body position requirements.
Make friends with the Control Riders (CRs) and pick their brains. They’re all selected for their riding skills, their ability to coach and their positive communication style. CRs take pride in helping those new to track riding to ensure they learn good principles.
The rest of us in the paddock may be simply waxing about our favorite technique that may do more harm than good for a new track rider.
Good luck and let us know how you get along.
Mobil 1 15W-50 Oil
Tire thermometer
Cable ties
Two mirrors
Plastic bag w/
Scotch-brite
Earplugs
Two Sharpies
Pen
Utility knife
Box cutter
Boot heel screws
Valve stem tool
Service book
Rags
White ruler
Awl
Flashlight
Plastic Tub
Tire pressure gauge
Electric Meter
Rubber hammers (2)
Two torque wrenches
Plastic bag w:
duct tape
electrical tape
sunscreen
pen/paper
gas can cap
syringe
tape measure
JB Weld
Never-seize
Very helpful.
