Landshark;76993 wrote: Not the same girls but should be similar in the result.
http://sportbike.natkd.com/road_rash.htm
^^^ That should be required reading for riding motorcycles. I think a lot of new riders don't quite understand what damage your body can take from an off.
I grabbed full leathers the night before last just to ride 15 minutes to a buddies house - it was after dark, and along the stretch of road I pegged a deer on last September in my pickup truck. I don't usually ride with full leathers unless at night, but I *do* wear gloves, 8" boots, jeans, a phoenix jacket with back protector, and helmet.
After seeing the damage caused to my truck by the deer, which coincidentally happened less than two weeks after my big off at Putnam, I ONLY ride with gear on now. The frame of the 3/4 ton truck was pushed back over 6 inches on the right side. The grill, transmission radiator, fan shroud, front fender, and the heavy duty bumper were destroyed. The battery was split. It took $2300 and 3 weeks of nutbusting work to get it road worthy again, as I only had liability on the old work truck.
The deer ran straight on to the road outside of my headlight cone, on the inside of a turn right out of a cornfield. I didn't see it until the moment of impact - the first glimpse of it was when it was about 3 feet in front of the truck. Didn't have time to brake, swerve, or brace myself.
If I was on the bike at the time, the outcome wouldn't have been good. Fortunately I was still WAY too sore to be riding from my crash at Putnam. Guess this means the crash at Putnam ended up saving my life two weeks later?? Never thought of it in that context until just now!
I know jeans won't be good for more than 5 feet of asphault... and that's a calculated risk I chose. I do keep my upper body covered 100%. The phoenix mesh jacket isn't uncomfortable even in the 100 degree heat index of August, as long as you're moving. It's got heavy armor on the elbows, forearms, shoulders, sides, and a full back protector built in. This is my second phoenix, and it has survived a low-side due to a gravel-filled pothole without any injury. I fared much better than my ZX-14 did, which still needs a coat of fresh paint...
I feel totally naked and exposed riding without gear. About the furthest I'll go is pulling the track bike out of the trailer and putting it in the garage, or riding it to tech in the mornings at the track.
Anyway that's my soapbox time..
