*** Pit Bike *** Schwinn S-1000 Full suspension electric scooter
steele11
asking $240/obo
Speed: up to 17 mph *
Range: up to 12 miles *
Motor: Powerful 1000 Watt, 36 volt, D.C. Neodymium Magnet. Finned motor casing provides better heat dissipation, semi sealed, dust and dirt resistant.
Controller: 36Volt/25Amp Pulse-Width Modulated Microprocessor with new self-diagnosis mode.
Frame: Full Size. Durable all steel computer welded frame.
Carrying Capacity: 260 lbs
Deck: Wide, 9'', extra thick ABS material resists cracking, won't dent, rust or rattle.
Front suspension: Dual shocks.
Rear suspension: Swing arm suspension with dual action mono shock. The rear suspension can be easily adjusted for rider weight or terrain.
Control panel: Features battery power indicator, power switch and charger port.
Drive System: All-weather direct drive. Gear Reduction System.
Throttle: Variable speed twist grip with built in led power monitor.
Battery: Three 12 Volt, 10 Amp sealed lead acid batteries in an easy to remove "Plug + Play" battery pack.
Expected Battery Life: 400+ recharge cycles.
Charger: 1.5 amp smart charger, 110V AC input, self-regulated. Led light indicate charge level. UL Approved.
Charging Time: 4-6 hours.
Battery Box: Steel, Easy Access cover.
Front Brake: Vented disc. Easy adjust.
Rear Brake: Vented disc. Easy adjust.
Tires: 12" x 3" Wide, Light Electric Vehicle Rated.
Wheels: Impressively designed five spoke, 12" cast aluminum alloy "Mag" wheels.
