JGardy_781
Guys -
I've had a brembo radial front brake master cylinder on my 02 GSXR-750 since I bought it, replacing the stock non-radial piece. The existing goodridge stainless lines were meant for the non-radial stock piece, so to get them to fit up to the brembo master cylinder's bolt, the lines were contorted quite a bit to fit up to the master, leading to what looked like a lot of strain on the lines themselves as they made the sharp 90 degree bend from horizontal to vertical instead of having a 90 degree fitting at the end of the line itself.
The lines are due for replacement, and while I'm leaning towards having yoyodyne make custom lines to fit the bike, I wanted to see if anyone used a set of lines from any of the major line manufacturers (goodridge, galfer, etc.) meant to fit another bike (maybe a later model GSXR that came with an OEM radial master cylinder) instead of having lines made. Or, did you just use lines meant for the regular fitment, and twist the master end around to get it to fit up..
Thanks,
Jason
Thanks,
Jason
