Yes, your body position is relative, speed, line, pace and type of bike. See your local neighborhood Nesba CR for more details. Body position is best taught at the track where someone can see your riding.BonesDT;142445 wrote: Does the amount of body hang off directly correlate to speed/lean angle?
What about perfect form for the street? Even though you are at a street speed and modest lean angle, is it ideal to hang off the seat as much as you would if you were on the track dragging knee?
Actually, I'd say the truly important factors crossover perfectly...avizpls;142450 wrote: Street and track dont really have a whole lot that crosses over like that.
:agree:TheGrouch;142471 wrote: Actually, I'd say the truly important factors crossover perfectly...
- Ability to brake as hard as the bike will allow, without locking up the front wheel
- Ability to accelerate hard out of a corner (or out of the path of an errant car) without spinning up the rear
- Understand how tight a line your bike can carve when leaned over hard
- Look where you want to go (not where you want to crash)
I learned these things on the track, with NESBA, but they made me a safer street rider.
:agree: I know it looks good when your hanging off while riding on the streetTheGrouch;142471 wrote: Actually, I'd say the truly important factors crossover perfectly...
rk97;142539 said:i'm guilty of hanging off quite a bit on the street. with questionable road surface, I feel it's that much more important to keep the bike as vertical as possible.
QUOTE]
I agree. I get nervous if I don't hang off a bit when on my street bike, with cold street tires, with unseen gravel/oil/etc.
It's been a while since I read it, but as I recall, Lee Parks talks in his book about just moving your upper body. Because you carry the bulk of your weight up high, just moving your head and shoulders to the inside of a turn can help without compromising stability. At least, it works well for me. I don't move my butt much, if at all.Ron P;142493 wrote: What you may want to consider for street use is what Reg Pridmore teaches. Rotate your pelvis around your gas tank. What that does is loads up your bike from the footpegs and spreads the inputs between the front and rear ends. It's not a full hang-off and gives you a good degree of control.
So, say I'm competitive racing around a hairpin turn on the track. Ideally, I'd be at maximum lean angle, knee touching, which means maximum body hang off. But say I'm going around a sweeper, or I'm doing a warm up lap, do I hang off less?Rydell;142739 wrote: You don't need to hang off on the street. The reason you hang off on the track is to displace your center of gravity to allow your bike to stay more upright, while cornering faster. If you are doing this on the street, you are probably going too fast - If you aren't going fast enough, you would look like a monkey. Just don't do it.
Actually, that's my point. Concerns about looking like a monkey aside, even if you are turning at a proper street speed, if you hang off, you can keep your bike even more upright, which is always a good thing, right?
Actually, my first question was more related to the track:
BonesDT;143555 wrote: Thanks for all the replies
In other words, if I wanted to practice my body positioning, would I be practicing a single position (full hang off, which I would use in every track turn on all occasions), or would I be practicing variable hang offs, a little, a moderate amount, and full hang off?
quoted for massive worth.D-Zum;143583 wrote:
On public roads I feel [the skills and techniques you learn riding with NESBA ] should be like that fire extinguisher behind the glass case that has, "IN CASE OF FIRE, BREAK GLASS"...only used in case of emergency.
I definitely start working on body position from the first warm-up lap. But I need all the help I can get. Not everybody does it, so far as I can see.BonesDT;143555 wrote: So, say I'm competitive racing around a hairpin turn on the track. Ideally, I'd be at maximum lean angle, knee touching, which means maximum body hang off. But say I'm going around a sweeper, or I'm doing a warm up lap, do I hang off less?
