I'm curious if you can fit race bodywork with a stock exhaust on a 2007 GSXR 750? Without modifying the bodywork. I know you can cut them to make them fit. My question then would be, don't you need a belly pan capable of fluid retention?
Nesba does not require you to have a belly pan. It is a good idea and if you race it is mandatory. I believe Armour Bodies will fit with the stock exhaust but I'm not sure give them a call. (978) 297-2977
Yeah, AB redesigned their lowers to work with the stock exhaust. I'd just mention it when you call to be absolutely sure, just in case they have some leftover older ones around because the old, original design won't fit, not even with a slip-on.
I have a 07 GSXR600 and race bodywork fit with the stock exhaust. That being said it was very very close to touching it. At some points it was probably millimeters away.
I ended up being an Akropovic slip-on since I was afraid the heat from the stock exhaust and catalytic converter would melt the race plastics.
