sternsi;21992 wrote: I would personaly never use them. It looks like it may put a huge dent in the frame with a big impact on it. Look on the GSXR how it covers the frame by the rear set. Not to mention if it catches on something, it will make the bike flip end over end.
are you suggesting that in such a bad crash, a bike with "frame" sliders would escape such damage? or in fact get LESS?
if you wreck bad enough to damage the frame, or the rail, you would have damaged the frame NO MATTER what you were using.
oh, and for those that dont know...there is a "puck" toward the front, in the SAME position a "slider" would be in. so THAT is the same. and in additional have the benefit of TWO mounting points, aswell as the bar in between.
ever seen a slider bolt bend/break? folding back, and wiping out the frame, engine mount, and everything else it was supposed to protect? i have, many times.
its the reason i chose these, over standard sliders.
its going to take a MASSIVELY bad wreck to do the same. in which case...it would have been badly damaged/destroyed anyway. this will just lessen the destruction.
wel, thats my take atleast...
sorry, dont mean to go off.
in the end, its "your" choice.
