devildogae
So I found a local shop that can drill holes for safety wire, so my question is what all should I wire up for next season? If anyone has pics of their wire jobs, a picture is worth a thousand words.
No need to pay a shop for it. It's easy to do. Buy a pack of cheap 1/16th drill bits from Harbor Freight, and go to town.devildogae;295039 wrote: So I found a local shop that can drill holes for safety wire, so my question is what all should I wire up for next season? If anyone has pics of their wire jobs, a picture is worth a thousand words.
Chain link is for chains that have clip on master links, not riveted. Unless you're riding some YSR50 or Ninja 250, EVERY track bike, regardless of displacement, should run a rivet master link.andykurz;295041 wrote: http://www.emra.ca/Tech%20Tips/Tech%20Tips.htm
I don't understand wiring the hose clamps & chain link, but it's a good primer nonetheless!
Otto Man;295042 wrote: No need to pay a shop for it. It's easy to do. Buy a pack of cheap 1/16th drill bits from Harbor Freight, and go to town.
There's two methods you could go with.mmmfishrighton;295068 wrote: One thing I would disagree with. Do not buy crappy bits. It makes it more of a PITA. The best bits that I have used are the Dewalt Titanium 1/16th. Found at Lowes or Home Depot.
Other bits will break way easier and I've yet to break a Dewalt.
Otto Man;295122 wrote: There's two methods you could go with.
1)Buy quality bits that will last longer
2)Buy a TON of cheap drill bits, and discard them when they aren't sharp anymore.
I went the 2nd route, and in my opinion, it's way easier. 1/16" drill bits are freaking tiny. Even the highest quality drill bits will break easily. I buy them in packs of 10 from Harbor Freight for like a dollar a pack. I will drill one or two bolts, and when it gets dull, I don't even waste time trying to sharpen them. I just throw 'em away.
Too much pressure on the drill bit is going to easily break it - whether it's a quality drill bit or not. The only difference with my way, is that I don't complain about snapping a $4 drill bit.
For anything bigger than 1/8", yes, quality steel bits make all the difference in the world in terms of longevity and retaining their sharpness. It's just not worth spending money on tiny drill bits for something as non-critical (In terms of precision hole sizing) as drilling bolts for safety wire. I will admit that I broke about 4 or 5 bits pretty quickly when I first started, but once I got the hang of how much pressure it would take to snap on, I didn't break them nearly as often. They went dull before they broke.
I safety wired most of the bolts for my R6 while they were on the bike. With the bolt torqued, I used a spring loaded center punch where I wanted the hole to be. I loosened the bolt a few turns, and turned it so the drill could fit. Drill it, re torque it, done.devildogae;295135 wrote: Do any of you use a jig? Right now I don't have a punch or vice or a place to put them.
Yes, I win, John and his crappy bits lose.devildogae;298483 wrote: Just an update for those interested in safety wiring for the first time. I did go get a center punch and vice + cheep bits. I drilled all my front caliper bolts now, but I did break the head of my bit off inside the caliper bolt. Then I went and got titanium bits, and wow what a difference a good quality bit made. I accurately was able to put pressure without snapping any. Worth the couple bucks I spent at lowes.
