Landshark;191406 wrote: You'll drag a toe first before a peg.
I now need to ask about your weight. Most stock bikes are not set up for a rider 200+ lbs. I think you are starting to see the progression of how mods become one after another. I would set the suspension up first. Rear sets if you can't fit properly and clip-ons to match ergo setup.
That just gets the bike ridable for the track. Now consider the factory flaws. GSXR master cylinders. Only 1-20 actually work well. GSXR calipers up to 2011 all can be swapped for Yamaha calipers. Stock they cause pad drag. 06-07 GSXR geometry. The entire bike needs a lift. Some washers for the back and slide the tubes down in the front.
I have owned both of these bikes. If you need any assistance with setting them up I'll offer what I can. I'm 6'0" and 220lbs. Height wise I fit but weight wise .... not so much.
Thanks for all the tips everyone.
As for me, i'm 6'3 and about 225lbs. I had Mark ( from markbilt ) set the stock suspension on my 1000rr last season and man did it ever make a difference. When I get the gsxr for the track, I plan on doing the same. I am not in a position to dump thousands on suspension components yet, but i will have the stock stuff dialed in more so for my weight. Plus as mentioned above.....getting better body position is what I am still working on.
Landshark, thanks for offering up the assistance when the time comes. I'll be contacting you down the road. I hope to have the bike in the next month or two as I will not be able to get back to the track till late july. I'll look to swap out the calipers as mentioned and raise the bike as well.
As for the master cyliner issues, can other master cyclinders from other bikes be swapped out and used or do i need to go the route of aftermaret higher end brand?
