JTRC51
Good articles that mirrors Dave Moss's teachings on tire wear. http://biketrackdayshub.com/motorcycle-tyre-wear-guide
Reading through this I was interested in the front geometry tear section only because I closely watch my rear tire wear patterns and not so much on the front, probably because the front feels so planted and well balanced. But if one were to have Geometry tears (i.e. too much weight or not enough weight on the front) how is that adjusted? raising rear, lowering front or vice versa ?? considering the spring rates also ?
Too much weight on the front
Cause - As the above heading would suggest, the other type of geometry tear is too much weight on the front. What happens in this instance is that when you start to turn the bike into a corner, because of the excessive weight on the front it will actually plough across the ground (rather than rolling), and it's only when you have finished turning the bike and get back on the gas that you take the weight away from the front end and the tyre is relieved.
As well as having too much weight on the front, this type of tear can often be caused by the front end being too soft in conjunction with too much weight.
Symptoms - What you'll see is a much smaller band of tearing that looks very similar to hot tear on a rear tyre, only the band will be about 5-10mm thick, usually about half way between the centre of the tyre and the edge. Again like having not enough weight on the front, if the wear pattern closely follows the circumference of the tyre it is most likely geometry related, if not pressure.
