madriders86;183431 wrote: Good info, thanks...looks like there is a fix.
How practical/easy is it to keep a 125 or 250 2 stroke running for trackday use? I've always been interested in riding them but the SV was easier...I just keep up on the basic maintenance and add zipties to keep the fairings from falling off and ride it
As for the gearing issue, I understand that it will be necessary to learn and apply that stuff at some point or another; however suppose I go into a corner and find that 2nd gear is too short and I run out of revs, but 3rd gear leaves the motor struggling to tractor through the rest of the corner, if that makes any sense....isnt the real solution more cornerspeed so that I can take the corner in 3rd with more revs? It also seems like a 125 2t would be far more sensitive to gearing changes than an SV due to the engine characteristics, but I could be wrong.
I'm just trying to keep it simple guys
Weeell as long as you guys are assuming I'm doing everything possible right
Next time I'm around the bike I'll count teeth. I have an extra set of wheels and everything. Can't remember if I have another sprocket carrier...
