Would using a laser temp gauge be a good way to fine tune air pressure? I've been running tire pressures in the low 30s hot on the track, but exactly where seems to be very subjective.
Checking to tire temp immediately after coming off the track would seem to be an objective way to make the remaining small adjustments? Drop pressure a little to increase temp vs add a little pressure if the temp is too high.
Does anyone do this? What would be considered ideal temperature?
For the record, I'm running DC3 rear and Dragon SC Pro SC2 on the front. I would assume that each may have a difference ideal temp.
