This is backwards, the twins have a much wider torque spread whereas the I4's have a narrow range given the need to have the RPM's very high. An I4 600 will keep you shifting up & down like a madman all day long!Matt H;20456 wrote: The twins you seem to do more shifting as you run out of revs quickly.
Maybe I could have been more specific. I did more shifting on the 848 (maybe I would have done less on a 1000cc twin) as I ran out of revs quickly. The 750's and 1000's did less shifting than the twin. The R6's I rode were about the identical in the amount of shifting (the I4 600 I shifted to keep the rev's up; the twin I shifted because I ran out of revs).hank;20585 wrote: This is backwards, the twins have a much wider torque spread whereas the I4's have a narrow range given the need to have the RPM's very high. An I4 600 will keep you shifting up & down like a madman all day long!
Matt,Matt H;20626 wrote: Maybe I could have been more specific. I did more shifting on the 848 (maybe I would have done less on a 1000cc twin) as I ran out of revs quickly. The 750's and 1000's did less shifting than the twin. The R6's I rode were about the identical in the amount of shifting (the I4 600 I shifted to keep the rev's up; the twin I shifted because I ran out of revs).
No doubt - I could definitely run the revs much lower and get GREAT pull. I rode the 848 for a number of complete days in total. I also came from a triple originally - I understand how to ride them differently. But the 848 would need to shift as often as a 600, which is more than a 750 or 1000 (the 750 and 1000 can pull from lower than a 600, but still have a lot of revs). The 600 v 848 probably uses the same spread of revs, just in different parts or the rev range (that's a guess). But for example, here's a breakdown. Trackdays. Summit Main. 1:19.rugbymook;20698 wrote: Matt,
You really don't ride a twin like you would an I-4. The bike won't "run out of revs" any faster, it just feels that way if you're used to revving out to 15k. If you were banging the rev limiter in 6th on the straight, the bike wasn't geared properly. Most people don't realize you can get a decent pull in the lower rpm's with a twin that you'd never be able to with the I-4 by using the fatter torque curve. I could probably short shift or run a gear higher in certain turns on a twin that i would need to shift to pull the same times on an I-4.
The 848 is a bit more rev happy than most twins. I have yet to ride one, but was to told that from Arnie Hastings and Dennys Passeto, who both race 848's after running big Ducati's prior.
I would guess that. Now if Ryan will just let me ride that "R"......rugbymook;20733 wrote: Ride a 1098 vs the 750 or 1k and i think you'll be shifting the same.
I think we all have that dream!oorguy:Matt H;20739 wrote: Now if Ryan will just let me ride that "R"......
The guy that let me do some laps on his Desmosedici ordered three 1098r's. I hope to get a few laps on one before hte season is over. I rode the regular 1098 and was impressed.Matt H;20739 wrote: I would guess that. Now if Ryan will just let me ride that "R"......
