What hand grips do you recommend?
Discussion in 'Tech Forum' started by Jgelack, May 13, 2019.
  1. Jgelack
    Jgelack New Member
    Id like to change out the stock grips on my bike and was wondering what grips you'd recommend.
  2. bmart
    bmart Control Rider
    I have Renthal on one of my bikes, but all of the others have stock. Did you wear them out?
  3. Motofun352
    Motofun352 Control Rider
    So many variables from soft, medium to hard. Also slick or sticky and thin to fat. Really hard to pick one for someone else. Make sure if you replace them to use some grip glue and safety wire them so they can't slip or twist.
  4. Jgelack
    Jgelack New Member
    No, not even close. Sometimes I find my right hand going numb, and someone recommended changing grips to something with a softer compound. Maybe I just need to lighten my grip on the bar a little more.
  5. bmart
    bmart Control Rider
    I think that you're onto something there... Also, you may find that your bar ends aren't heavy enough. My little 400 can do that to me with out holding on at all...
    tdelegram likes this.
  6. jcurtis
    jcurtis Control Rider N2
    I like the Renthal soft grips. For the right hand going numb, yes, a lighter grip is recommended. You may also want to look where your brake (and clutch) lever is located. You want it located so that when you are squeezing the brake your hand is in-line with your forearm. I see a lot of people who have the brake lever too high so your hand is rotated up cutting off circulation at the wrist.
  7. bmart
    bmart Control Rider
    Interestingly, that is how most bikes come from the factory.
  8. Jgelack
    Jgelack New Member
    Rental grips seem pretty popular. I did adjust my levers so they are in the correct position, so I don't think the numbness is a result of that. I do believe I need to work on lightening my grip on the bars. Sometimes I just have so many things going through my mind that I forget to keep the weight off the bars, I will have to work on that. Thanks for the advice guys!
  9. jcurtis
    Let me know when you are planning to ride and we or one of our instructors can go over some body position techniques that help you relax arms/hands.
    Sent from my Pixel 3 XL using Tapatalk
  10. bmart
    bmart Control Rider
    Any coach is happy to help. Unsolicited advice...pick one thing to work on each session, adding to the last session. Muscle fatigue is popular (I used to be near death after a track day). We had a rider last weekend at NC Bike who was considering going home as his appendages (keep it clean!) were killing after a few sessions. We talked about it a couple of times. He finally "made it happen" and hung out for the rest of the day, without the sore muscles!
  11. bacolmm
    bacolmm New Member
    I like Renthals but they sure do wear out quickly. The stock grips seem to last the longest...
Share This Page
