Thanks for the replies. I believe it is a Baxley wheel chock and it is mounted to the trailer floor. Even without the straps the bike doesn't really move but everytime I've borrowed it I strapped it. I just wondered if it was necessary.Rasta;52989 wrote: YES, two at the front and two at the rear. Dont compress the front too much either, it puts stress on your fork seals. Comp. the rear then stabilize the front. Also try to angle the rear tie down straps a little forward, so that it pulls the bike into the front wheel chock.
How can you tie down a bike without compressing the suspension? Certainly there's no need to bottom your forks, but you do have to tie it DOWN.lemondrop;53012 wrote: DO NOT COMPRESS THE FRONT SUSPENSION!!!! I did this going out to AZ....needless to say, I was riding on springs once I got there....
Here's what I do:
get some good ratchet or tie downs that can loop back on themselves...loop one on each side around the lower triple and either back to the chock (not sure baxley has the available mounts) if the chock is attached to the bed/trailer. Then loop or hook on the subframe or if you have the pillion pegs (I hook around the subframe just above the rearsets)...then attach other end to something forward. secure these tighter than the front ones. The front ones should be taut....not tight...you want the suspension to be able to work a little....
yes, you are correct that the suspension does compress fully a couple times during a track day...however, it is also allowed to decompressing immediately afterward. If you have it tied down, it is not able to decompress.fizzer;53027 wrote: How can you tie down a bike without compressing the suspension? Certainly there's no need to bottom your forks, but you do have to tie it DOWN.
Compressing suspension does nothing to fork seals. Your forks compress fully a couple times a lap under braking, no sweat. I wonder where the fork seal myth came from?
Yikes! Last time I took my bike Atlanta I had it strapped down so it couldn't move at all! Shit!lemondrop;53049 wrote: yes, you are correct that the suspension does compress fully a couple times during a track day...however, it is also allowed to decompressing immediately afterward. If you have it tied down, it is not able to decompress.
I'm no suspension expert, but I do know that I lacked all comp/damp properties after having the bike fully strapped down on my trip across the country.
Yes, the bike down need to be tied down, but if you have a decent chock and the rear stabilized, the tie-downs are for guidance/support and not to ratchet the bike to immobility.
If this were not the case, then PitBull and STStands wasted a bunch of money....
:agree:Joe Vital;53160 wrote: pit bull restraint system
Are your eyebolts secured to a wooden floor? If so, you don't worry that they will pull through?Drewbie;53173 wrote: I fit two bikes in an 8ft bed side by side. I only tie down from the rearsets forward to eye bolts in the bed that are 1ft forward and out 6 inches out from each side of the bikes. Bikes never go anywhere. I dont use chocks just put the wheels into the bed wall.
