Can I can use a front master cylinder from an '07/'08 CBR 600RR on my '03 600RR? My reservoir, which is integrated with the master cylinder was damaged in a crash. I would like to replace it with a separate reservoir/cylinder assembly like the '07/'08 bikes in case I go down again. It looks much simpler and cheaper to swap out just a damaged reservoir, as opposed to an integrated assembly.
I have considered a Brembo package, but the '07/'08 Honda pieces are considerably cheaper, and I can't imagine that I would notice the performance difference at my skill level.
On a similar note...can anyone recommend a good set of SS brake lines? I'm running the stock lines, and would like to change them out at the same time as the master cylinder.
Thanks,
-Mark
Thanks,
-Mark
