JWZelibor
looking to upgrade after this season
FS 2006 F250 turbo diesel-Crew Cab 4door-shortbed
83k miles on the ODO
Larit package
tires in good shape
Rotella oil used in all changes
FORD FILTERS only used
Brand new STAGE 1 Performance MFG Crate motor installed @ 79K miles
stage 1 motor includes
*ARP Head Studs Pre-Installed
*Ford OEM head gaskets
*NEW MAHLE .020 Oversized Pistons and Rings
*3-Angle Valve Job done In-house
*New Injector Cups Installed
*Heads are milled to ZERO tolerance of warpage while still maintaining factory specs.
*NEW MAHLE Rod Bearings, Main Bearings, & Cam Bearings
*New LOW PRESSURE Engine Oil Pump Included
*ALL OTHER ENGINE GASKETS PROVIDED
**NEW ENGINE OIL COOLER-FORD OEM
asking $26,500
Larit package
tires in good shape
asking $26,500
