Thank you! I'm 3mm shorter than stock right now... wonder if that could explain some of my unusual tire wear? :idea:Jtfjrrider;205079 wrote: Ok. Re-measured center to center dimension as 12 inches. So looks like your notes are good. Wasn't reading the tape measure correctly.
shock length has nothing (as far as i know) to do with tire wear. it primarily effects turning and overall stability.Jtfjrrider;205281 wrote: Your welcome. As far as your tire wear? I'm new to this track thing.. Maybe someone in the know about these things will speak up?
add tire preasure will afect tire wear, to the list as well.sobottka;205287 wrote: shock length has nothing (as far as i know) to do with tire wear. it primarily effects turning and overall stability.
rear tire wear problems are usually spring/preload or damping related.
