Fo for those of you who regularly pit on VIR's north course or CMP what do you put down over the pea gravel/dirt to create a more suitable pit space?
I've noticed some put down indoor/outdoor carpet, some use a chunk of plywood, some others use that same fancy hard rubber mat flooring the AMA pro teams use. What are the pros/cons of each of these? Anything else people use?
Is whatever solution you use strong enough to park your bike on or do most of you park it between the edge of the asphalt and the yellow lines?
